Stock?
I have been asked to get up a list of materials, about a thousand dollars worth, that a local wholesaler can have in stock for radiant jobs. This specifically for radiant work only. I told the gent that asked that I see the need for nothing more than a few rolls of half inch barrier tube.
I said just the tube because when I do a job, I install the loops and tie them together to do a pressure test with a homemade gauge that will go up to about 100 lbs. Setting the manifolds and pressure testing through them leaves the manifolds there to be damaged by the other trades that come through.
Seeing as we are quite far from the hotbed of radiant work, the list need to be kept simple. Most other materials, like manifolds and controls, can be ordered because there won't be a pressing need.
Thanks.
Jeff
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=159&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
