how do the s\s modulating boilers compare to cast iron?
hr
Member Posts: 6,106
of these small condensors is the ability to supply low radiant temperatures efficiently and without additional mixing devices.
The bonus is the modulating feature which helps keep them running without a lot of on/off cycling.
Easy to vent, sealed combustion. Electronics that have a bunch of features like DHW priority, outdoor reset, data logging, etc.
What's not to like.
I've used Munchkin and Weil Ultra, Most recently the new Lochinvar Knight built down around your area :)
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
What's not to like.
hot rod
Getting the right boiler for my house
I have a 2500 sq. ft. house in north Ga. with in floor heat. I have used Burnham cast iron boilers in the past, with good results. How do the Munchkin or Trinity stainless wall hung units compare?0 -
- 86.8K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
