Mounting Danfoss valve with regulator vertical
bb
Member Posts: 99
Keith:
We really mean it. If the operator is installed in the verticle postion the heat gets trapped inside and shuts off prematurely causing the room to under heat.
If you need to install an operator in the verticle positon get Danfoss Code #: 013G8252 - Valve mounted operator w/ remote sensor, or the wall mount versions: 013G8562.
Warm Regards,
bb
Warm Regards,
bb
Danfoss. . .
I noticed that the product literature in my brand new Danfoss valve is very specific in stating that the regulator must not be put in the vertical position. . . but when they say MUST, do they really mean it? Will there be successful operation otherwise?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
