Mono Flow Tees
carl_15
Member Posts: 21
their should be an arrow indicating a supply direcrion and a return direction. the arrow pointing in the supply direction should be pointing TOWARD the risers.
Mono Flow tees
I had a boiler installed and was wondering if the mono Flow tees were in the right direction.They are made of steel IPS and have two arrows One pointing right and one pointing left. The right one says Return and the Left says supply. Which one should be pointed to the header ( Circulator is pumping away). I have a radiator that is the opposite of this that won't get any heat.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 101 Chimneys & Flues
- 5.6K Gas Heating
- 101 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 934 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
