I have an uninsulated slab thet I want to put radiant heat on.
Boilergeek
Boilergeek Member Posts: 42
Easy floor is a plastic grid floor system that will give you a vapor barrier with an area of convective energy dirrected up and not down. It is topped with some mass via hardy backer board. I have used it on one slab on grade project and it is great and easy to install. I plan on using it on my own house when we remodle in the spring.
Of all the dry systems I have used it seems to be the best choice.
