short cycloing steam boiler
thfurnitureguy_2
Member Posts: 74
If the boiler is sized right, it won't build build much if any mesurable pressure. Is the boiler shutting off by the stat being satisfyed? Main Vents let the air out of the main pipes quickly so your radiators at the end of the run can heat before the stat turns off your boiler. Low or no pressure on the gauge is a good thing. Check your main vents and post the length of your mains.
short cycling steam boiler
I am trying to touble shoot a non-functioning branch on my one pipe steam system I think the boiler may be short cycling, but need help diagnosing. I have replaced the pressure gauge with a 0-15 psi gauge. The boiler gets up to .5psi, but no more. Even if I adjsut the cut out to 2.5 for testing, the pressure gauge never gets above .5psi and the boiler cuts out. Cut in rate is set at 1psi. One branch on my system seems to work, the other three radiators on another main do not work at all. Likely other issues in additiion.
Thanks for any help0 -
If they're missing, stuck or undersized, steam distribution will suffer. Measure the length and diameter of each of your mains, and tell us what vent is on them.
additive, or subtractive differential ...???0 -
Not sure what you mean-- the cut out rate on the control says that is it the cut in plus differential. I have cut in set at 1 and differential set at 1. I adjusted differential to 2 just for testing, but pressure gauge never went above .5psi.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
