Bullheaded tee, how bad?
Steamhead (in transit)
Member Posts: 6,688
but newer ones are much less forgiving. Get rid of the bullhead.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I'm replacing a steam boiler and wondering whether to go to the trouble of eliminating a bullheaded tee.
The old boiler has two 3" outlets to a 3" offset header, and one 2-1/2" takeoff that goes up about 25", then turns horizonal another 25" before hitting the tee, sending the steam into the two mains. It all seems to work fine -- steady water level, no banging, etc. (The boiler's being replaced because of a crack).
The new boiler has one 3" outlet. It'd be easiest to just take the old 2-1/2" riser off a new 3" header, but I realize the kosher way would be two take-offs, one for each main. Since the tee is so far from the header and the old boiler doesn't surge, how important is the extra work to elimiate the tee?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
