booster pump
Matt_21
Matt_21 Member Posts: 140
booster pump for my sprinkler system. the sprinklers are fed off the city water. about 2' from the water meter, i installed a tee. the branch line will feed into the pump. the pump is only activated when one of the sprinkler zones comes on. should i be concerned if i try to use my domestic water while the pump is running. i'm afraid all the water will be diverted to the pump and i won't get anything to the faucets. any thoughts?
