Elec h.w. heater for radiant heat
ALH_4
Member Posts: 1,790
I'd use a <a href="http://www.laing.de/65Download/10Prospekte/english/pr_ra_eur.pdf">Laing EPR 6kW</a> heater. Everything in one unit.
-Andrew
-Andrew
ELEC, HW HEATER FOR RADIANT
HOW WOULD YOU SIZE A ELECTRIC HOT WATER HEATER FOR A SMALL RADIANT HEAT JOB.0 -
water heater
personally i wouldnt do it that way but to began whats your heat load how many btus
elec hw heater for radiant
heat load of 14000 btu's0 -
Electric water heater
Time to take your shoes off. 1 KW=3413 Btus. But like the man said, why? The make-up/recovery time is sooo slooow.0 -
There are times
when an electric source is a good one. Certainmly for small loads like that a gas or oil fired boiler is not in the cards. and gas fired DHW tanks are fairly in efficient.
I've used 2-1/2 gallon and 6 gallon tanks for small radiant jobs. A six gallon tank with a 4500 watt element yields 15,345 BTU. Just about right for your application.
Thermolec.com makes small modulating electric boilers with reset control built in. Not a bad unit for small radiant jobs and a bit more substance (controls, limits, safeties, etc)than a basic tank style water heater.
hot rod
THANKS HOT ROD FOR THE INFO0 -
Here I go again
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 5.7K Gas Heating
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 6.3K Radiant Heating
- 392 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 46 Industry Classes
- 49 Job Opportunities
