Installing steam air vent
bob young
Member Posts: 2,177
best method is weld a boss [threadolet ] on main .
Drilling and tapping into steam pipe
I need to install a 3/4 inch pipe (for an air vent) near the end of the 2-inch main pipe. This main appears to be very hard to drill and tap into. Is there a best way to do this? Please e-mail suggestions to sizzlaw@optonline.net0 -
new vent
.......or cut the main and thread in a new tee. No easy way. Drilling and tapping a 3/4" pipe into a 2" main IS NOT an option any pro would consider doing.0 -
Do you need 3/4-inch?
How much air do you need to vent? How long is the main, and is it all 2-inch pipe?
The main is about 25 ft long with several tees for branches to radiators along the way. The existing main vent is probably 30+ years old, will not close, and is on a 1/8 inch nipple on the elbow (at the end of the main) that directs the condensate downward. I have been told that the vent should not be on the elbow but should be about 15 inches back from it and that a high capacity vent on a 3/4 inch nipple would result in faster heating of the radiators, which I would welcome.0 -
I believe the main is all 2 inch pipe.0 -
Cut and weld
Shoot a small hole with a torch and then weld on a threadolet or a extra heavy 3/4 inch coupling which may be easier to find. Leave a loose 3/4 in cast iron plug in while you weld. This sounds like a big deal but with the little portable torches and 120Volt welders I could do this in about 1/2 hour if I walked in with clean steel and access on the top of the pipe. In an old house this is definately a 2 person fire watch job, clean up everything before you start and wet down near wood. Then have a water hose ready to go. One unnoticed spark in an old basement can ruin your day.0
