Ball Valves
Paul Rohrs_5
Member Posts: 134
Most valves have a WSP rating stamped on the other side which is "Working Steam Pressure".
PR
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=353&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
PR
I was wondering if some one could tell me what the WOG that is stamp on the side of ball valves stands for...
Bob.0 -
here you go
Water, Oil, Gas
Cosmo Valavanis0 -
ball valves
thank you Cosmo,my Boss gave me this mission to find out what it ment. He made a good point in saying that I should know seeing how I use them almost every day...lol
thanks again Bob0 -
Thanks Paul, I'm sure that whould be the thing He'll ask.0 -
I always thought that was
"Water Service Pressure", but you may be right.0 -
WSP on ball valves
Paul is correct. WSP on ball valves stands for "Working Steam Pressure" and is generally a lower pressure that the WOG, or "Water, Oil, Gas" rating.0 -
S,SP and WSP
all mean the same. The maximum rated or working pressure corresponding to the steam temperature that must not be exceeded when the valve is used in steam service. CWP This is the maximum flow-medium pressure at the ambient temperature to which the valve may be subjected during normal service. This is also referred to as water-oil-gas(WOG) rating. These deffinitions are from Piping Handbook by Nayyar.0 -
Thanks, Dave and Bob
Always learning on The Wall...
The only ball valves I specify for steam are Jamesbury-Neles, but maybe I can expand that list just a bit...
Thanks again-
Brad0
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
