Toe kick design?
Brian V
Member Posts: 7
Hi all,
Got as question for you. I'm in the middle of adding a second floor to my home. Current system is a hydronic baseboard. To my 2nd floor I've added 2 additional zones, bathroom to be off the smaller sq ft of these 2 new zones.
Baseboard is not an option in the bath, please don't ask why......mumble grumble, Toe Kick is the only way I can think of.
Now to my question...all of the Toe Kicks I'm seeing are 1/2". The loop itslef is obviously 3/4. Not wanting to restrict the flow thru the zone I'm a bit perplexed.
Do I:
A, run the zone thru the 1/2" Toe kick and not worry about the restriction.
B, run the Toe kick in parallel to the zone, obviously more flow will go thru the 3/4" but "some" should still pass thru the 1/2"
Toe 1/2
----|----|-------3/4
C, Take the 3/4, Tee it into (2) 1/2" runs with the Toe on 1, bypassing the Toe on the other.
Toe 1/2
3/4-----|---1/2---|-----3/4
Hopefully the ascis come out right.
Thank you for your time!
-Brian
Do I:
Toe 1/2
Toe 1/2
-Brian
