GB142 and Mass. Approval
Kevin__Flynn
Kevin__Flynn Member Posts: 74
So without an H-Stamp and only being approved in Mass. as a "Heater". what can it be installed to do?
Kevin Flynn
  • dconnors
    dconnors Member Posts: 215
    We have Mass. approval on the GB142 condensing heaters as of today. I promised to update all of our friends here on the wall. Its a good day in Mass.
  • Dave Heath_2
    Dave Heath_2 Member Posts: 52
    H Stamp approval for Canada
    Dave, When can we expect the H Stamp approval for Canada. What kind of approval did you receive for Mass.?
  • ScottMP
    ScottMP Member Posts: 5,882
  • dconnors
    H Stamp
    application is in process and I will advise asap.
  • Ted_9
    Ted_9 Member Posts: 1,718
    Must install one now
    Great, finally. Its also on the front page http://www.buderus.net/default.aspx
    PATRIOT HEATING & COOLING, INC.
  • Ray Landry
    Ray Landry Member Posts: 203
    niiiiiiiiiccceeeeee
  • Kevin__Flynn
    Dave
    What is it approved as without an H-Stamp???????
    I noticed in your post that you chose to use the word "Heaters"
    Kevin Flynn
  • Wayco Wayne_2
    Wayco Wayne_2 Member Posts: 2,479
    Question about GB142
    I called Buderus and asked about outdoor re-set and the GB has none to this date. They are working on getting one. I thought they oughta have one built. Seems a waste to have modulation without a variable set point. I know Munchkin has the vision 1 kit you can add to get Outdoor reset. Does the Ultra and the Vitodens come with it already installed??? WW
  • Darin Cook_3
    Darin Cook_3 Member Posts: 389
    Outdoor reset will be out in a few months
    Tekmar is making it for them. To all who have not used this excellent piece of equipment yet, you will love it. Pricing falls in between a Munchkin and a Vitoden$. The included primary/secondary manifold insures proper flow rate thru the heat exchanger. You can vent it with standard sch 40 PVC. No $pecial vent kit.
    Darin
  • ScottMP
    Wayne
    Vitodens has it, I don't know about Ultra.
    My understanding is the GB is setup for a indoor reset by way of a room sensor. Nice for a single zone application but tough for our multi-zone applications. They are working on it and it will be out later, just as Munchkin brought out vision one later.
    This is really a European single zone boiler which will take a little time to be fully intergrated into the US design but will be well worth it. IMHO.
    Scott
  • tim smith
    tim smith Member Posts: 2,935
    Weil mclain's does have od reset
  • ScottMP
    IS the Ultra
    a variable reset or are there preset points on the curve ?
    Scott
  • dconnors
    you are correct
    It is approved as a heater. In the near future it will have the H-Stamp and be approved as a boiler. We will only offer it as a boiler when that approval is finished. This should avoid the confusion as to which one to order as there will only be one version.
  • Roy Woolley_2
    Roy Woolley_2 Member Posts: 6
    approvals
    Baxi Luna has had aprovals for Mass and NYC for some time, plus H stamp. Watch this space for the new condensing range of wallhung boilers, wallhung comercial up to 1/4 million BTU's too.
    Enjoy...
  • Hey, what's the ETA on those, and has Baxi addressed the DHW temp fluctuation their older units have had?
  • Rookie
    Rookie Member Posts: 175
    Taco plug ins
    This is great news I have delayed a job, so the homeowner could have the GB-142 installed. I will use the TACO expanable zv control board with the taco plug ins for the outdoor reset and the injection.
  • dconnors
    In Mass.
    It can be installed to do your heating and domestic hot water. We are pursuing NYC approval.
  • hydronicsmike
    hydronicsmike Member Posts: 855
    Buderus GB - tekmar Controls
    As I understand it, the Buderus GB Series Wall-Hung Modulating Boilers can now be operated by a tekmar Modulating Boiler Control 270 or just about any tN4 Reset Control (except for 421 Mixing Reset Module) if used with Buderus'es EM-10 Interface Module.
    Hope this helps. If you have further questions, you are always very welcome to call me at 250-545-7749, Ext. 214, OR call Joe Kennard or Dave Connor at Buderus at 603-552-1100.
    Regards,
    Mike
    PS: Beautiful Job Darin!!
  • van_2
    van_2 Member Posts: 20
    NJ
    What about NJ approval?
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    My first 1,
    Arrived today. I took delivery about 40 minutes ago. Tomorrow we begin. I'm so looking forward to this !
    Removing the old GlowCore unit today was the highlight of the last winter(better late than never). The problems that it caused will NOT be missed 1 bit. I'll try to keep a running log in photos for posting . Thanks Boss! Chris
