pressure drop
Roy Woolley_2
Member Posts: 6
Thanks for the comments gents.Also thanks for the valid comment about the .doc attachment. I used that format to cut out all of the unnecessary information. Just that when I did the math the pressure drop was larger than I thought it might be....so thought I was doing the math wrong.
Once again thanks for the input, you can always get a straight answer here. REW
pressure drop
Can anyone convert this chart into North American. Any help would be greatly apreciated.0 -
Conversion
I asume you want the x-axis to give you gpm. Simply divide the gallons per hour value by 60 (60 minutes in an hour). If you want to convert the y-axis to psi, divide the value by 2.31 (2.31 ft = 1 psi)
Good Luck,
Rich C.0 -
Also..
Replace the commas with decimal points.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
