Leaking Boiler
Daveyt
Daveyt Member Posts: 2
Hi all
I have a 4yr old Weil/Mclain boiler WTGO series installed in the basement filled with glycol and appears to be leaking around the 1-1/2 in fitting on the bottom rear side of boiler.
I have tried in the past to tighten this plug with out much success, as space is very limited.
What I would like to know is there a compound unlike what one would put in a car radiator to stop small thread type leaks without compromising the zone control valve operation?
Daveyt
