adapter plate
Paul_44
Member Posts: 14
Is there an adapter plate that can be used to change the mounting angle of a circulator pump flange by 90 degrees?
understand
not sure on what plane your looking for ....On a horozontal you should be able to spin the flange..If hard to spin cut it down to the pipe and knock it off.Spin on a fresh kit... Does this help ?0 -
Yes
this is on the horizontal plain. It is a soldered flange and I didn't want to disturb it.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
