TRVs and evolution...
John S.
John S. Member Posts: 260
some one-pipe TRVs in my home and I'm very happy with the outcome. No longer do I have rooms that even slightly overheat the way they used to and distribution/balancing is much better.
Maybe someone already makes this or maybe there's a good idea why NOT to make this, but is there such a thing as a programmable TRV?
It seems silly to me to have a relatively deep setback at night, yet keep the same TRV setting. I suppose if the vents are balanced well enough it should not make much of a difference.
Curiousity, alone, prompted this post. I'm eager to hear any thoughts on the subject.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=366&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Arthur
    Arthur Member Posts: 216
    Programmable TRV.
    Heimeier, Make one Known as 'Thermostatic "E" head'
    7 day programmable C/W anti theft mechanism,antifrost position, normal or setback temperature adjustable. Does require power though not sure about operating voltage as it's a German make,
    http://www.heimeier.com/en/index.asp?art=explorer&g1=2&g2=15&g3=0&g4=0&g5=0&g6=0
  • DWood
    DWood Member Posts: 60
    RA plus
    Danfoss makes a battery operated set back unit as well. You have the option of setting up two programs with up to 3 set back periods a day and you choose the days of the week you want to run each program. The RA plus will fit any RA 2000 valve body.
    DWood
