Anode rod for an indirect ?
Darin Cook_2
Member Posts: 205
I was down at Triangle Tube a few months back and specifically asked about the issue on the island with the indirects. I was told that the issue was taken care of. Do yourself a favor and call TT and talk to Jim or someone else on the engineering staff. They will help you in any way they can. On a side note, we watched them foam insulate the weil indirects. Cool!! I cannot believe some manufacturers are still using fiberglass. So call down there and get the answers you need.
Darin
Darin
I just changed out a Phase 3
that was installed in 2004 . The one before that lasted 4 years . My neighbor is on his 4th indirect in maybe 6 or 7 years . This has been an ongoing problem for our company for years ( not just ours ) . Almost all of Long Island is hooked up to municipal water . I think the failure of these tanks has something to do with fluorine or chlorine , some kind of ..ine . I was wondering if an anode rod would be beneficial to preserving the life of these tanks ? Since I have a Weil Mclain Gold Plus under my stairs I don't want that one to let go anytime soon . Thanks in advance .0 -
leaking indirect
Watch out for high chlorine levels in the water the chlorine will attack the chromium in the stainless steel mix.0 -
current
Stray current will also attack the tanks. Check rom the water piping to a known ground- like a ground stake for any amount of voltage. Normally I have seen the tanks fail at the point of electrical convergance, like the aquastat well.0 -
I know...
...anodes have been used to help keep stainless tanks going in the past. Seems there isn't much to lose by trying ;~) Unless someone gives you a good reason not to, I'd stick with magnesium.
Yours, Larry0 -
We saw that in a home once
We were changing out aquaboosters in this house every few years . For some reason we cut out a tee in the main pipe and the lights flickered . Tell tale of a bad neutral in the house .
But I know this isnt the cause for the leaky indirects . Too many homes spread out over Long Island .0 -
Yep
I got an email from a buddy of mine at Weil about my own indirect . That is good to hear about the issue . Phase 3 is my favorite indirect - not too heavy , heats up faster than most indirects , built in aquastat , separate tapping for a recirc line . Thanks Darin .0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
