condensate waste
jim krovats
jim krovats Member Posts: 1
can you tell me the requirements for acid neutralizing in the condensate waste? as well, can you advise who manufactures these.
thanks
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Depends on your local plumbing code
    If you have PVC piping I am not so concerned, cast iron I would be. Viessmann makes a neutralization kit but you could cobble one together out of PVC pipe (4" with screwed end caps and some tees) and marble chips. Not scientific but it works.
