heat exchanger
Couderay
Member Posts: 314
Have a primary secondary system. I was wondering the best way to install a heat exchanger on my system. The heat exchanger is for a snow melt. My piping size is 1 1/4" copper and have circulators for all zones. Zones are 3/4" in size as well as the piping to the snow melt. I have not purchased the exchanger yet but have a bypass in the primary loop set up with a balancing valve, as this was where i was going to place the exchanger. Any info would be of great help thanks. Joe
Joe,
I am working on a similar "Budget" job with 2-zones of radiant floor heat and 1 zone of snowmelt. What kind of boiler are you using and is it sized for the job? What Category snowmelt are you trying to achieve. What controls are you currently using?
Regards,
PR
yes it is sized to the job at hand it is a munchkin 140m not sure what is meant by "category" you are refering to it is for a 18'x20' concrete slab which is on a walk out basement very well insulated and with 2 wing walls and is covered by a deck. controls will be using an aquastat with bulb in sensor tube placed in walk out hope this helps0
- 167 Indoor-Air Quality
