Honeywell boiler aquastat
Ted_9
Member Posts: 1,718
We repiped an existing boiler and replaced the existing tankless with an indirect. Now is there a way to disable the low limit on the aquastat, say by disconnecting a wire? Do I need a new aquastat?
The new zones and indirect are controlled by a new
taco zone controller and the indirect is off the Tekmar.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=343&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Reverse Aquastat
To delete a """reverse"""" aquastat you can jump it out.0 -
To disconnect the low limit
on a triple aquastat relay you do the following:
Remove the wire from the "B" terminal on the R-W-B side and jump out R and W.0 -
