can i install 1 1/4\" copper into a steam system?
matt_33
Member Posts: 1
i cut out existing pipe going from first fl to 2nd and want to replace it with copper. is it ok?
Most of the
steam fitters use black steel pipe; less expansion/contraction that could lead to failure.
copper steam line
If you must use copper it would be wise to braze your fitting to help ith the expansion and contraction.I would also use "L" type tubing. Myself I prefer black iron pipe with castiron fittings
John0 -
gwgillplumbingandheating.com
2nd no
On condensate that would be fine.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
