Opinion on Vaughn Indirect tanks?
hr
hr Member Posts: 6,106
forever. IF, this is the same tank as the old Ford stone lined? They were used for solar tanks and I have a couple in my shop and home that are 20 years old.
They hold there heat a long time after the sun goes down, also :)
Not for lightweights to install.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Cosmo_3
    Cosmo_3 Member Posts: 845
    Anybody have any long-term experiance with these? From what I have seen Vaughn Indirect water Heaters are manufactured in New England, and their selling feature seems to be a thick stone lining to protect the steel tank. Although I have not put one in, there is a local supply house that is pumpin' these out like hot cakes..... I wonder if they are just cheaper?
    Cosmo Valavanis
    Dependable P.H.C. Inc.
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    I have used...
    plenty of theses in the past...they were ok. The new design (top performer) does give you a faster recovey than the old HX40. They listen to contractors about making improvements.Their selling point is also there weak point...the cement lining. VERY heavy. I supose that is the only reason I don't use them much. Other than that they are fine.kpc
  • ScottMP
    ScottMP Member Posts: 5,882
    I found
    the gaskets can be prone to leaking and the recovery not very fast.
    The newer tanks do have a better recovery than the old tanks which was right up there with electric HWH :(.
    Scott
