Panel Rads Below Loop
I want to get a kick in the right direction, I have a 1" loop running above 2 panel rads and 2 towel warmers. I had planned on using 1" X 1/2" Monoflos on the Supply AND return spaced the width of the rad. I plannned it this way because the rads are ALL below the main loop, My questions are these; Will I have a problem possibly if the Thermostatic valve closes? And Is there any rule that says how close one mono can be from another NON related rad? In otherwords can you put a supply mono right next to a ret mono from a previous rad? I know we mix them when its above and below but I am not sure what to do here.
Any ideas?
Thanks in advance,
CC
