hot water radiators
john boulais
Member Posts: 1
is anybody know of a recirculating hot water system where the radiator is built into the wall? thanks
Sure
It's not so much the radiator as the construction detail. You just have to frame the wall so you can indent the radiator. You also have to make sure you provide enough room below and above the radiator for good air flow.
burnham makes sunrads & govanale makes recessed cabinet types.0 -
Radiant walls
You may want to look into doing radiant in the walls.
What is it that you are after?
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
