Buried Water Pipe
Type K Copper.
Robert O'Connor/NJ
  • gehring_3
    gehring_3 Member Posts: 74
    Buried Water Pipe
    I want to trench and bury a seasonal water supply line to an out building that is about 150' away from the main house. What would be the best material to use for that?
  • buried water line
    I would use pe pipe with a ball valve & drain valve at the house so as to drain down in winter.
  • EJW
    EJW Member Posts: 321
    Under ground water
    Use Pex. If it's seasonal set it up so you can blow it out with air. EJW
  • Bob Sweet
    Bob Sweet Member Posts: 540
    I think the drain down capability is the key.
    I'd even consider using sched. 80 pvc.
  • tls_9
    tls_9 Member Posts: 89
    I'd
    I'd like to suggest you check your local and state codes. There might be some requirements to take into account.
    tom
