B&G Zone Valve ?
Mike C_3
Member Posts: 62
there are multiple zones. 4 I think and this on particular zone is the only one with a problem. I was thinking maybe a wire or a zone controller was a possible problem. The plumber didn't give me any info on what exactly went wrong.
I had a plumber ask
me today what I thought and don't have a clue.
Here's the skinny!
B&G comforttrol or something simmilar, he has had to replace it about 6 times now in the past 12 years or so. all the other valves are and have been fine. what's up with that? I was thinking wiring problem but i'm sure someone here has seen/fixed this problem!
Thanks in advance!0 -
Hey Mike...
What is actually failing on the zone valve? Is it electrical or mechanical problem?
Mike T.0 -
not sure
sorry0 -
nobody can help?
hmmmm0 -
You wanted to know but
I asked you if it was an electrical or mechanical problem and you weren't sure. How can anyone help? could be 100 different causes of malfunction. I was just trying to narrow it down a-little.;-) In addition I would think there is likley an electrical problem if it works fine for a while then fails. I think you said there were multiple valves installed.
Mike T.0
