thread dope
midway_2
midway_2 Member Posts: 42
Question. one pipe steam system, from what I've read on here I believe everyone says to use pipe dope instead of tevlon tape on threads to radiator vents and the main vent at the end.
  • Couderay
    Couderay Member Posts: 314
    Pipe dope
    I use rector seal #5 for all threaded joints coat the male threads wipe excess off and I then put a "nick" of dope on the female threads (small amount). Tighten accordingly.
  • midway_2
    another question on this, When the vent has to be replaced again in a few years, will there be trouble removing it due to useing the dope? Thanks
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    In my experience
    using pipe dope makes taking a joint apart possible ... without a Sawzall.
