CK 61 Fields woes
Firedragon_4
Member Posts: 1,434
he is one of the good guys, FACT!
Tim Begoske
810-599-9212
e-mail: tbegoske@provide.net
<a href="http://firedragonent.com">www.firedragonent.com</a> <P>
Tim Begoske
810-599-9212
CK 61 Fields woes
Hi fellas,
I'm struggling with this timer relay on a CK61. The first one didn't work; I suspected the electric killed it because it was all screwed up (wiring, that is). So I get there today ready to rewire the world (oh I forgot to mention the wiring diagram had vanished as well), and I totally spaced and hooked a N wire on the timer relay to a hot. My brain is fried after this heat wave we had-
This is an oil job with SWJ, and a Beckett/Honeywell primary; I'm sorry I forget the actual model.
Is there a way to comfirm when these things are actaully dead? My big issue is the fan keeps running and running- it will not shut off. Thanks for any tips-
Gary Wilson0 -
Not sure if this will help or not but i worked on a fan in the can vented hwh one time that had the same complaint about fan running constantly... the air pressure switch was stuck in the closed position.... I replaced it w/ new and had the same problem.... talked to feilds and there is actually a 5mm allen screw which you back off to relieve the pressure which builds up inside the switch. if your switch is always sensing pressure than it's giong to assume there is a flame burning.0 -
air switch
I'm not sure I follow you; it's the fan motor of the power venter that makes the air switch.
Gary0 -
Gary,
The Field Controls web site has wiring diagrams.
Leo0 -
try this
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
