Hydronic Geo-them Unit W/ High Velocity AC Unit?
GMcD
GMcD Member Posts: 477
If you are already running the tubing, why not run cool water through the tube and get some radiant cooling out of the system, and then use a small HRV unit (required anyway) with a supplemental cooling and heating coil for the peak period touch-up control. Step #1: reduce the loads of the house! Step #2: reduce the heating and cooling loads of the house!! Use very high quality windows with good solar control and you should be heading in the right direction.
  • Bill Heintz
    Bill Heintz Member Posts: 1
    Incorperating a Geo-therm Hydronic system w/ a high velocity AC
    I am planning to build a new home. I would like to go with a geo-thermal (hydronic-radiant) HVAC system. I would like to avoid using traditional duct work. Are there any systems that run with High Velocity AC units? I look forward to any comments or suggestions. Thanks
  • CDM2
    CDM2 Member Posts: 18
    Geo- High Velocity A/C
    Unico Systems can utilize a hydronic coil with their high velocity- mini duct system. You can use a water- to- water geothermal unit for both your hot water for radiant, and chilled water for A/C circulated through the hydronic coil in the Unico System.
    You can contact me direct through my e-mail for more information.
    dm
