Buderus Boiler with panal rads
Big Ed
Member Posts: 1,117
you can balance them by the out put size or use the TRV valve. When using the TRV, pipe the radiators either a home run hook up or use the diverter valves....
hay guys I have a buderus g115 28 with lt 160 and 2107 control I want to add panel rads to 2 bedrooms and one bath room. my question is with the bf indoor sensor will the panel rads and baseboard heat work ok together
id like to put a panel rad in my living room but I don't have wall space both my sofa's and 65 inch TV is taking up the wall space so I need to add baseboard in there.
I also have full baseboard on the other half of my house
where the t-stat and bf sensor will be
I am going to have 2 007 one will power the baseboard side and the other will power the 3 rads and 10ft of baseboard
should all this work happy together
thanks
thanks big ed yes i am going to pipe it ina home run and branch off of a taco 007 with 4 loops and 4 panal rads each rad will have it's own supply and return
thanks0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
