Hot Water vs. Steam Radiator
Susan_6
Member Posts: 42
I have a one pipe steam system and an old radiator with thin sections. Can this be used in for a hot water system? Someone wants this radiator that I no longer want.
thanks.
thanks.
If this rad
has a perfectly flat top, and openings at the top of the end sections (which will have plugs in them) it should be OK for water. They will have to plug the opening for the steam vent and drill & tap for a hot-water vent at the top, and also remove another plug for the second pipe needed for water.
If you're not sure what you have, take a pic and post it here. We can tell you for sure.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Baltimore, MD, USA
Consulting0 -
Thanks -- it sounds like it just might work.
Susan0
- 129 Chimneys & Flues
- 122 Geothermal
