Gold plus 80 or 100
Al Letellier
Member Posts: 781
I have 5 heads in my shower and make hot water with a tankless coil in a WTGO-3 boiler and don't run out in a normal shower. That PLUS 80 will give you all the hot water you need and probably then some. Just add a mixing valve and your "golden"
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=248&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Concerned about dump load
am retro fitting a Ultra 230 for a customer who has a large domestic hot water demand. First shower in morning will have 3 shower heads @ appreox. 10 gal a minite load. I dont want to be excessive but I want to cover my butt is the Plus 80 enough or should I use the Plus 100. Also has large garden tub, but will not be used at the same time however will be used one after the other. Thanks0 -
First Hour ratings
Your first hour ratings using the Ultra 230 with a plus 80 at 115 degrees is over 440 gals. Having virtually the same set-up in my house, I can tell you it works just fine and you're well covered.0
