Control for pool heat exchanger
Davco
Member Posts: 1
I am hooking up a Phalen heat exchanger to my boiler (WM ultra 230)system. I would like to utilize my multizone relay controller (Argo ARM 6P). I need a 24 vac water stat to wire into the controller to start the boiler and circ pumps for the heat exchanger circuit. Any help appreciated.
You could use...
...a tekmar 150 Setpoint Control.
www.tekmarcontrols.com
Mike0 -
You can look at an L4006A1959 from Honeywell - it does not do all the functions of a Tekmar but it is cheaper in price0 -
I'd lean
toward any thermistor type setpoint control. Make sure it has an adjustable differental setting that allows a fairly tight range.
I prefer the brands with large digital displays. Tons of choices out there. Johnstone Supply catalogs 4 or 5 different brands.
hot rod
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
