hot water shortage in the winter time
ed wallace
ed wallace Member Posts: 1,612
you must have a tankless coil the mixing valve is bad needs replacing or better yet if you are the homeowner think about a new boiler and an indirect water heater that would solve your problem
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=354&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Karolina
    Karolina Member Posts: 9
    Hi,
    We have an old "22" Kohler oil boiler I believe from 1950's.We are absolutely happy with the heat that this boiler produce, but have shortage of hot water during the winter months. My oil service company reset the temperature limits in the beginning of the winter, but that didn't help. Any ideas of what can cause that problem? Any professional recommendations?
    Thank you,
    Karolina
  • Karolina
    thanks, for your reply. Yes, I'm a homeowner of a three family house, and have tenants that complaint about this problem.
  • A perfect candidate
    for an indirect water heater . If sized right , hot water should never be an issue again . A higher upfront cost is offset by the recovery rate of these tanks , as well as a lifetime warantee on many models .
    The coil in that old Kohler did you proud , but after 50+ years and hot water needs for 3 families , it's time for retirement . Our company frequently gives discounts when a boiler and indirect are installed together . Good luck Karolina .
  • Karolina
    Where your company is located? I live in Staten Island New York.
