superstor off steam boiler
Todd Ficociello
Member Posts: 1
Does anybody have a diagram for running a superstor and a zone of heat off of a steam boiler ?Any help would be appreciated.
I'm not sure about the superstor but here's what you need to know for a zone off a steam boiler. and that zone could possibly go to the superstor if there are enough btu's available?
As Dan would say it pays to wander off the wall
Your friend in the industry,
Alan R. Mercurio
www.oiltechtalk.comThere was an error rendering this rich post.
Alan.
How did you make the link you provided say what it says, and not just the link itself. Boy did that sound dumb? Do you know what I mean?
Robert O'Connor/NJ0 -
....I have instructions on their way to you...
... as long as that e-mail address you have here is valid. Cheers!0 -
If the boiler is large...
... and the pressure relatively high, you can even "fire" an indirect water heater like the horizontal Vitocell from Viessmann with steam. They offer some impressive recovery rates in that application. However, most residential steam systems don't have the spare capacity to do this right.
Instead, you could zone a hydronic loop off the bottom of the boiler Given the temperatures of steam systems, the recovery rates ought to be impressive. Alan's link to Dans knowledge says it all, as far as implementation goes.0 -
Constantin.
Thats for your help. I know I'm still in the stoneage with all the 'putor stuff, but I'm gettin better, with your help.
Thanks Again!
Hi Robert, Here's a cheet sheet I used when getting started and I often refer back to it
HTML Tips & Tricks
Alan R. Mercurio
Thanks Alan.
I need all the tricks I can get.
Remember though
that the indirect should be prioritized to shut down the heat when the tank needs to be replenished . The pickup factor on the steam boiler should be a non issue with an indirect . I'm still waiting to install my 1st indirect directly off a steamer . I wonder if there is any difference in recovery time compared to a hot water boiler ?0
- 129 Chimneys & Flues
- 122 Geothermal
