How can I tell if I have a low water cut off?peerless boiler.
On Long Island we're required to install a LWCO on every boiler regardless of size . That's a requirement in many areas nowadays .
I have a EC series boiler,I use a indierct water heater but my boiler does have acoil ( I just don't use it) I was wondering how can I tell if I have alow water cut off, the boiler is less then a year old. Thanks0 -
Joe
If you could post pics of your boiler and the near boiler piping we cant tell you in a new york min.0 -
Hi, i can't post picks.0 -
Follow the wiring,The LWCO will either be Taco,McDonnell-Miller or Hydrolevel
I have ataco circulator, I have the expanison tank, the flow control vavle (or what ever it is called) and I have to zone vavles, that i can see.0 -
LWCO
What state do you live in Joe? Are you worried about your system being up to code? Most low water controls on a system that new would be installed in the feed pipe coming out of the top of the boiler.0 -
Most forced hot water boilers dont have LWC around here. Not needed unless the boiler is above the heating system.0 -
I have read on here that it is a good idea to have one, I was just wondering if I had one or not, I know myu fill vavle will kick on if the pressure gets low.0 -
A hot-water boiler under 400,000 btu imput is exempt of needing a low water cutoff0 -
You hope...
Fill valve failure is the main reason low water fuel cut off devices were invented.
Cheap insurance and peace of mind IMHO...
ME0 -
Any picks I can look at to see if ai have one?0 -
Here's an ECT we installed
last year , the only hot water ECT I could find . The low water cutoff is in the boiler supply , below the expansion tank tee . It's the green Taco . On your boiler , you want to look for a device that might be right above the boiler and has a wire going into it .
It'd be easier for you to describe exactly how many devices are connected to the boiler with wiring , and tell us the name and model number of each .0
