dumb plumber and steam boiler repair
ed wallace
Member Posts: 1,612
went on a call last nite no heat steam boiler plumber told customer she needed a new hw 8600u control because tstat wasnt cycling boiler his temporary solution was to remove wire connected to the 24 volt terminal and run a wire from 24volt hot on transformer to 24 volt terminal on the hw 8600u control there by bypassing all the safeties the pigtail was plugged gauge was reading 8 psi cleaned pigtail everything works fine now if you dont know what your doing dont touch it call for help
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=354&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
- 120 Geothermal
- 394 Solar
