How many square feet of CI radiation can pex handle
Mike T., Swampeast MO
Member Posts: 6,928
Unless I know:
1) The size of the CI radiation (in EDR)
2) The heat loss [requirement] assocated with such radiation.
3) The expected average temperature of such radiation.
How many square feet of CI radiation can each of these sizes
handle based on the chart I have from an earlier question:
3/8 Pex= 5/16" .3125" 1.6 gpm
1/2 Pex= 7/16" .4375" 2.3 gpm
5/8 Pex= 9/16" .5625" 3 gpm
3/4 Pex= 11/16" .6875" 3.67gpm
Same question, different approach
How many BTU/h can I pump through the different sizes of PEX? So I know how much radiation I can stick on the end of the run of PEX. I don't need exact, just something close. I don't think PEX will push the same amount as copper, but I may be wrong.0 -
You could push MORE thru pex than copper...
It's SMOOTHER!
Delivered btu's on the other end depends upon your desinged delta T.
Think wide delta T with cast iron radiators.
Like 30 to 40 degrees F.
gallons X pounds X delta T X time = btuH
So, 2.3 X 8.33 X 40 X 60 = 45,981 btuH
If each square foot of radiation deilvers 180 btu/sq ft /hr, then your 1/2" pipe at 2.3 GPM and a 40 degree delta T would carry approximatley 255 square feet.
ME0
- 120 Geothermal
