Why is my sight glass so dirty?
Joe Moody
Joe Moody Member Posts: 22
When you flush the boiler you are only cleaning a portion of the whole heating system. You may want to try a steam clean such as Squick to clean up the system.
  • Pat_17
    Pat_17 Member Posts: 23
    I regularly drain the furnace water and also the returns but the bottom third of my sight glass is very dirty even when the water I drain is clear. Any answers and a possible solution would be great. Thanks
  • Ron Schroeder
    Ron Schroeder Member Posts: 995
    Pat
    Does the water in the glass jump a lot it could be that it is oil on top of the boiler water, you probably need a pro to skim the boiler.Any oil and dirt on top makes it hard for the steam to break through.
    Bruce
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,827
    Your sight glass is dirty...
    Because your water is dirty...
    Ed
  • Pat, it may be necessary
    to power-flush that boiler. There is probably a considerable amount of dirt and sludge on the bottom of the boiler. Simply draining it probably won't get rid of all the dirt.
    This is a job for a pro.
