radiant manifolds
Andy_17
Member Posts: 30
Installing a radiant system in my home w/ 6 different zones, each zone has from 2-6 loops. The plumber wants to install Embassy pvc manifolds. Is the brass manifold worth the upgrade. Any problems w/ Pvc manifolds Or Embassy products?
In my garage radiant...
I am using the plastic HeatLink manifold system. In my area it's sold through Johnstone supply. I have used it on several radiant job's and I like it enough to use it in my home.0 -
I have a job...
I am going to do soon. I am replacing all 5 plastic embassy manifolds. I know at least 2 other contractors who have to replace them....kpc
what type & brand will the replacements be?0 -
probably Wirsbo...
or should I say Uponor...Embassy does do brass manifolds.kpc
any benefit to using wisbro vs. embassy?0 -
What is the tubing?
If the tubing is Embassy use their manifolds...the warrantee may depend on that....kpc
- 120 Geothermal
