Humming Furnace
why does it humm, cause it can't sing. Just kidding, look for incorrect orfice sizing or gas pressure or gas piping size. 99% sure your pressure of set wrong or not enough volume.
Peace Be With You
David C. Broome
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=390&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Peace Be With You
David C. Broome
Weatherking Rumble
Help.While installing a new furnace at a two family house my attention was drawn to the newly installed 2nd floor furnace. Someone installed a Weatherking model 90RJ10EGS01 2 YEARS AGO. Every time this furnace fires up it makes a harmonic rumbling sound through the heat exchanger. The unit vibrates and rumbles for about 45 seconds, (warms the exchanger) then disappears until the next cycle. The installer came back 2 times and told this little old man that it was normal. I have been in the HVAC Business 20 years, it is not normal.....any ideas?Help.While installing a new furnace at a two family house my attention was drawn to the newly installed 2nd floor furnace. Someone installed a Weatherking model 90RJ10EGS01 2 YEARS AGO. Everytime this furnace fires up it makes a harmonic rummbling sound through the heatexchanger. The unit vibrates and rummbles for about 45 seconds, (warms the exchanger) then dissapears until the next cycle. The installer came back 2 times and told this little old man that it was normal. I have been in the HVAC Business 20 years, it is not normal.....any ideas?0 -
how is it installed? upflow? horizontal?
check the IOM and see if the basics are done.0 -
I know this is too simple but is there a really long flex connector? I see it all the time, grab the gas line when it's making the noise and if it changes the sound either shorten it or re-pipe. I only keep 3/4 lines on the truck so I don't have to mess withit on my own installs. Check the manifold pressure while your at it. Also check the static inlet pressure. Sometimes a monster inlet can make the gas valve do amazing things.0 -
Orafaces
Had one problem with harmonic sound same thing another said normal to humm.
Gas pressure was high 4.5 " and oraface size was small and not spec. The temp rise was good but that humm went through the whole house..
Smile and share one
Terry0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 107 Geothermal
- 70 Pipe Deterioration
- 983 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
