monoflow tee
KevinM_2
Member Posts: 3
The tee's are about 15 inches apart and the convector I am picking up is around 4 feet long. I only need to drop down about 3 inches before jumping back up. What is a plm?
Thanks,
KevinM
Thanks,
KevinM
monoflow tee
Hi, I was moving a couple of heating lines in my basement up into the bays to gain some headroom. The line I am moving is a monoflow main . This main serves convectors on the first floor. Is it ok to drop down first out of the bay with the supply and return branches and then jump back up to pick up the convector and still use a single monoflow tee on each convector, or do I need to use two?
Thanks !0 -
how much
How much are you dropping the main? How far apart between the tees? I have dropped to 20" without a plm, as said before, every job is differnet and must be looked at before any decisons are made....0 -
Read this:
All about Monoflow tees
And this:
more great stuff from Dan's site on Monoflow tees
"It pays to wonder off the wall"
Thanks Gary, very helpful.
KevinM.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
