Heating Problems
Michae;l Norskog
Member Posts: 1
I have a two story house and my heat will not come on inside my house. My heater is in the attic and I have a thermostat on the first floor. The Thermostat reads that the heat is on but the heat is not blowing through the vents. I can hear the heater in the attic but it seems that the blower is not kicking the heated air out? What could be the problem?
Check the filter
could be
If the blower motor is not activating or the motor itself is gone the unit could be cycling on high limit. No matter what's going on you need someone to get in and check it out...0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
