What is this gage?
jeff_50
jeff_50 Member Posts: 13
Can anyone tell me what the function of this gage is?
Thanks,
Jeff
  • Michal
    Michal Member Posts: 213
    looks like
    just under the center of the arrow it says steam ****** the flash covered the rest, so it could also be a steam pressure gauge, now looking closer and seeing that 1 through 5 are marked off, I would most defiantely say its a steam pressure gauge, and the word steam is a big plus on the face. The purpose is to tell you the pressure within the boiler
  • jeff_50
    The gage is on a 60+ year old Weil McClain
    steam boiler. The boiler is still humming
    but I think the gage is shot.
  • Carl PE
    Carl PE Member Posts: 203
    Does that say
    "steam vapor"?
  • jeff_50
    AND...it says Steam 'Vapor' where the flash obscured
    the word.
  • bigugh_4
    bigugh_4 Member Posts: 405
    ITSA~
    Steam gage for an vapor steam system . The idea here is the low increments marked at 5#'s and below. Most steam heating boilers were set at 1# or less, operating pressuer. Noel of Slant Fin can espouse upon this magnificnetly!
  • bob young
    bob young Member Posts: 2,177
    what you got there is a BLOWN steam gauge
  • Dale
    Dale Member Posts: 1,317
    I've got one like that
    Except the pointer is bent on mine from Way too much vacuum when the boiler was converted to gas and the vents didn't or weren't designed to open. Too bad gauges of that quality aren't available today.
    Steamhead Member Posts: 17,651
    You're right
    it's a steam pressure gauge with the scale arranged so the increments between 1-5 PSI are easier to see. Unfortunately, the pointer being where it is tells me the gauge is kaput. Replace it, and add a pigtail to the new one.
    Consulting
