Boiler :
Harry Sanichara
Member Posts: 1
My circulator pump is on the return side, would that cause my system to take 45 to 50 minutes to heatup i have a triple aqustat
how big
How big is the system? Is it one zone or multiple? Is the boiler sized properly? Is the circulator actually working? Has this alway's been a problem or something that has just come to your attention. Sound's like you may need someone to come in and check your system over. It could be as simple as the aquastat is to close together on the low and high temps and the circulator is not activating until the unit is almost to high temp....0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
