weight of cast iron rad
Karen
Member Posts: 2
Hello,
I am just about to move some cast iron rads. I was trying to estimate the weight of a 2 column 32" high coil. Does anyone have a rough estimate per coil so I can calculate the weight of the rads?
Karen
Karen
radiator weight
If you have a 4 tube 25" height shipping weight per section
is 9.2 lbs.0 -
for your radiators
I'd estimate 23lbs/10.4kg per section.
-Michael
- 129 Chimneys & Flues
- 122 Geothermal
