Vertical air eliminator
Jim M
Member Posts: 29
Does any out there know if the Spirovent junior air vertical has a tapping on the bottom of the seperator for connection of the expansion tank.
Thanks in advance
Jim
Thanks in advance
Jim
Not on any of the ones I have seen.
go to spirotherm.com
all the juniors I have used have the tap on the bottom, but you called it a vertical and I don't think I have seen that one if it is differant than the standard jr.0 -
I would like to see someone make one that sweats 90..*~/:)
then it would be simple to fix some of the older systems...
an if you mean the air eliminator one those i pretty much use on a riser off pipes way up in the ups and downs of systems reasoning that it will help get rid of entrained air much more quickly and also eliminate air from long distance travel back to the one near the pump.0
- 167 Indoor-Air Quality
