What B&G pump is equivelent to a Taco 0011
Tony_23
Tony_23 Member Posts: 1,033
PL 36 looks about the closest curve, although depending on application a PL 45 may be better.
  • Couderay
    Couderay Member Posts: 314
    circulators
    Was wondering what B&G circulator is equivelent to a Taco 0011. Pump is going to be used on a hot water tank loop off the primary loop on a primary secondary system.
  • If you want to stay with a wet rotor design
    go for a Grundfos UP 26-96F (Up 26-96BF if you need it it bronze)
    Good luck.
    RC
