GlyAnti-freeze boiler help
Eric_13
Eric_13 Member Posts: 4
I have everything needed to antifreeze my fathers boiler. Is there a set way it has to be done? I was going with a 50/50 mixture.
Is it as simple as draining the boiler into containers, taking the amount of water and cut it in half, pump water and anti-freeze back into the boiler?
Thanks for the help
  • ken_36
    ken_36 Member Posts: 17
    antfreeze
    Make sure you only use a boiler anti-freeze. I find out how much a boiler holds then determine the approx capacity in the system. The containers will tell how much to dilute to be safe. You can also test the concentration. Most boiler anti-freeze is -100 full strenght. Just do not use car anti-freexe.
  • ken_36
    What kind of system do you have? System will depend on how you will remove air without loosing anti-freeze.
  • ALH_4
    ALH_4 Member Posts: 1,790
    Premix
    Mix it as you pump it in.
    -Andrew
  • S Davis
    S Davis Member Posts: 491
    Keep in mind that it will affect your system pump capacity.
    S Davis
    Apex Radiant Heating
